Range of time series chart
Hi, I have a time series chart and the data are dynamic query binding, those queries change so the max values of your data change too, so I don't put a min and max value of the axes but I have a problem, for some reason the label numbers in the axes have many decimals, How can I reduce the number of decimals without putting a number in that space?
In the same place you circled in the screenshot, expand the tick section, expand the sub item label, then change format to maybe ".2f"
You are right, thank you very much
