Range values displayed on Classic Chart ? - Ignition 7.9
Hello, is it possible to add a reference range as a solid/dotted line on a classic chart in Ignition Designer 7.9?
I've seen tons of "easy chart" examples but was needing a range displayed on an existing chart.
Using Vision not Designer.
Here is an example of the reference range for example, but I would like two straight horizontal lines, one at lower and one at upper bound. or this highlighted area reference range is awesome too, are either of those possible?
Update: I believe this may be the solution but going to double check tomorrow and see if this works! #gridbands Vision Chart: Interpolation and visual bands
Yup. That should work.
