Rate of transition from master to backup pc
  1. The test was conducted with 50 tags on the master pc.
  2. It takes an average of 2 minutes and 20 seconds to switch from master pc to backup pc.
  3. Please let me know if there is a way to speed up the transition time.
That is astonishingly slow. I have customers with redundant systems with tens of thousands of tags that transition in single digit seconds (after the configurable detection time--typically ten seconds).
Oh, wait, you tagged this for Perspective. /:
Yes, we're testing with perspective right now.
Is it fast if I do it with vision instead of perspective?
This might be something better handled via support.
Either way, you aren't explaining how you're inducing failure/failover and what it is you're actually measuring in terms of how long it takes.
Yes, what I described above was Vision.
Then is there any way to speed up on perspiration?
Well....
I haven't used Perspective with redundancy. Sorry. Someone else will have to chime in.
:sweat_smile:
What do you mean?
Does that mean there's no way?
He (Phil) means that he hasn't used Perspective / Perspiration™ with redundancy so he doesn't know.
But you haven't answered Kevin's questions
