When Open Report Template in designer then it shows error like:
ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
caused by GatewayException: Read timed out
caused by SocketTimeoutException: Read timed out
Ignition v8.1.37 (b2024013011)
Java: Azul Systems, Inc. 17.0.9
If anyone has insight on this topic, please kindly share your thoughts
Thank You
Thank you for replying. Could you please tell me the solution for this error?
When I use this named query then it is taking lot of time and after report template is not open
How long does the named query take when you run it by itself? (Using the default date/times configured in your report.)
(Also, your named query is more than one statement. While that can pass through to drivers that support SQL scripts in JDBC, JDBC officially only supports single statements. Beware.)
