Re-format string to single lines
I have string stored in a database. It is the output log of IBM CPLEX
When I retrieve it into Ignition, it is a single (long) line of text of type :class com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset
The string has many line separators \n
How do I reformat this to display in a text component that looks like:
! --------------------------------------------------- CP Optimizer 22.1.1.0 --
! Minimization problem - 12 variables, 27 constraints
! TimeLimit = 1
! LogVerbosity = Terse
! Initial process time : 0.01s (0.01s extraction + 0.00s propagation)
! . Log search space : 16.8 (before), 16.8 (after)
! . Memory usage : 441.6 kB (before), 441.6 kB (after)
! Using parallel search with 8 workers.
! Best Branches Non-fixed W Branch decision
0 12 -
  • New bound is 34920
  •     45320       15  0.12s        1      (gap is 22.95%)
        45320     2024          7    1   F        -
  • New bound is 40120 (gap is 11.47%)
    45320 2024 7 1 -
  • New bound is 41799.95 (gap is 7.77%)
    ! Using failure-directed search.
    45320 2031 7 1 F 2399 >= startOf(O_103#0#P2#O_1
    03#12000.0)
  • New bound is 45316 (gap is 0.01%)
    ! Search completed, 1 solution found.
    ! Best objective : 45320 (optimal - effective tol. is 4)
    ! Best bound : 45316
    ! Number of branches : 19044
    ! Number of fails : 11218
    ! Total memory usage : 4.5 MB (4.5 MB CP Optimizer + 0.0 MB Concert)
    ! Time spent in solve : 0.12s (0.12s engine + 0.01s extraction)
    ! Search speed (br. / s) : 170035.7
Thank you
sorry
all sorted now
Please either share the solution or delete the thread. As it stands the thread is useless for anyone else. Thanks!
Returned the query as JSON format, selected data[0] and returned it to textArea.
This component did the rest
