I have several TVs that have there own App running on the. Once an hour I want to retarget them to another project for 3 minutes and then have them return to their original app. I have the smarts to do the time but getting an error when I test with a button script.
I am using 7.9.2 Ignition.
system.util.retarget(“Copy_Of_Hallway”,“192.168.59.240:8088”, {“retargetOccured”:1}, [“Safety”])
I want this to invoke from a Timer Client Script when Finish and Return from a Client Script from the retargeted project
This is the Error
Error Launching application
SAXParseException: The element type “link” must be terminated by the matching end-tag “”.
This fix this issue
system.util.retarget("Copy_Of_Hallway","192.168.59.240:8088:8043/main", {"retargetOccured":1}, ["Safety"])
Code I used to change project and then back after set time.
Get Current Min and convert it to INT
today = system.date.now()
Min = system.date.format(today, “mm”)
#Get Time to Show Hallway Project
tagread = system.tag.read(“SLI/Charlotte/Bakery/TVs/Hallway/Line 3 TV Time”)
switchtime = tagread.value
iMin = int(Min)
#Goto Hallway Project
if iMin == switchtime:
Dest = system.tag.read(“SLI/Charlotte/Bakery/TVs/Hallway/HallWayTVName”)
system.util.retarget(Dest.value,“192.168.59.240:8088:8043/main”, {“retargetOccured”:1}, [“Safety”])
Dest Code
#get Min and conv to INT
Min = system.date.format(today, "mm")
imin =int(Min)
#get variables
project = system.util.getGlobals()['_RETARGET_FROM_PROJECT']
gateway = system.util.getGlobals()['_RETARGET_FROM_GATEWAY']
ChkTV = project[-2:]
returntime = system.tag.read("SLI/Charlotte/Bakery/TVs/Hallway/Line 3 TV Time Ret")
#if called from another project check return time and then call original project.
if ChkTV == "TV":
returntime = system.tag.read("SLI/Charlotte/Bakery/TVs/Hallway/" + project)
if returntime.value == imin:
system.util.retarget(project,"192.168.59.240:8088:8043/main", {"retargetOccured":1},["Safety"])
