Hello everybody! If you’re in Europe you’ve heard this situation of the GREEN PASS.
I can read the QR code using a barcode reader than I have this “encrypted” string, does someone have done something to read it?
thank you in advance
It looks like it should be pretty doable to manually decode, although you may have to use some Java libraries in place of Python libraries. The decoding process is described in this repo, for instance:
