I am trying to move value of 1 tag to another tag's eng low or high. I tried bunch of syntax but no luck, I am sure some of you might have done it with proper syntax.
You cannot. The documentation describes how engLow and engHigh can be bound to UI components to control data entry operations. You cannot bind the other direction.
You must use a change event script on the source tag to write into the target tag's properties.
