Read tag value with a perspective component change script
Hi everyone;
I am working with a Label and I have created a text change script as seen below:
And I would like to read the value of a tag that is bound to a PLC. is that posible with the system.read.Async? or there is another way to read a tag value?
Best regards
It is possible, but I doubt that you actually want readAsync in this case. I assume that you are wanting to read the value to be used later on in the script?
tagValue = system.tag.readBlocking(['[YourProvider]YourTagPath'])[0].value
Though I kinda feel we have an xy situation here.
Yeah, very possible. I rarely use a one line tag read like that so I seem to always for get to add the member reference.
Thanks,
It doesn’t works
i want that every time that I press this button, read the tag value (wich is an integer data type) and assigne to the label
There is no error in the script that I can see that would make it write the value of the tag to the text property. Are you getting an error reported?
If this is on a button, then the script should be in the actionPerformed event, not in a value changed script.
Youe are right, I was doing it wrong. thaks a lot!
