Read Time out for QueryTag History
I am having following error :
Java Traceback:
  File "<input>", line 395, in <module>
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:556)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runTagHistoryQuery(GatewayInterface.java:802)
	at com.inductiveautomation.ignition.client.script.ClientTagUtilities.queryTagHistoryImpl(ClientTagUtilities.java:342)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.queryTagHistory(AbstractTagUtilities.java:737)
	at jdk.internal.reflect.GeneratedMethodAccessor369.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
	at org.python.core.Py.JavaError(Py.java:545)
	at org.python.core.Py.JavaError(Py.java:536)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:400)
	at org.python.pycode._pyx574.f$0(<input>:834)
	at org.python.pycode._pyx574.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1703)
	at org.python.core.Py.exec(Py.java:1747)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 18 more
Caused by: java.net.SocketTimeoutException: Read timed out
	at java.base/sun.nio.ch.NioSocketImpl.timedRead(Unknown Source)
	at java.base/sun.nio.ch.NioSocketImpl.implRead(Unknown Source)
	at java.base/sun.nio.ch.NioSocketImpl.read(Unknown Source)
	at java.base/sun.nio.ch.NioSocketImpl$1.read(Unknown Source)
	at java.base/java.net.Socket$SocketInputStream.read(Unknown Source)
	at java.base/java.io.BufferedInputStream.fill(Unknown Source)
	at java.base/java.io.BufferedInputStream.read1(Unknown Source)
	at java.base/java.io.BufferedInputStream.read(Unknown Source)
	at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
	at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
	at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:450)
	... 26 more
You are asking for more data than can be retrieved in the designer's hard-coded 60-second time limit.
(You tagged this as Perspective, but the stack trace shown only occurs in Vision Clients or in the designer script console.)
"Hard"-coded modifyable via settings? or baked into the code?
This. There is zero interest at IA at changing that.
