Hi all,
I got this problem when I try to run a query from a table in PMI and I haven’t got any result. But the query is too complex and it takes nearly two minutes when I run it in SQL Server Management Studio. I tried to set the connection time using fpmi.system.setConnectTimeout() function. But I still have that problem. Please let me know how to solve it. I also pasted the error message.
Message: Connection lost because of following error:Read timed out
Time: Thu Mar 3 2:56:45PM
Severity: ERROR
Logger: factorypmi.common.gateway_interface.ConnectionStatus
Stack Trace: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.factorypmi.common.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:192)
at com.inductiveautomation.factorypmi.common.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:152)
at com.inductiveautomation.factorypmi.common.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:148)
at com.inductiveautomation.factorypmi.common.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:454)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:321)
at java.lang.Thread.run(Unknown Source)
Stack Trace: java.net.SocketInputStream.socketRead0(Native Method)
