I’m trying to load a decently sized project in the designer (20MB? That’s approximately what the “Loading Project” dialog shows as a maximum when it occasionally succeeds) over a ~30Mbps home internet connection (although the actual speed is anyone’s guess, as is usually the case). The “Loading Project” dialog shows an approximate maximum of 500kb/s as its download speed. After it gets ~4MB in, loading the project fails with a Read Timeout error:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:543)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:945)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.loadProject(DTGatewayInterface.java:358)
at com.inductiveautomation.ignition.designer.project.ProjectOpenTask.run(ProjectOpenTask.java:26)
at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:364)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.ChunkedInputStream.fastRead(Unknown Source)
at java.base/sun.net.www.http.ChunkedInputStream.read(Unknown Source)
at java.base/java.io.FilterInputStream.read(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface$ThroughputMeasuringInputStream.read(GatewayInterface.java:582)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityManager$RewindableInputStream.read(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipChar(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:485)
... 7 more
Ignition v8.1.12 (b2021111810)
Java: Azul Systems, Inc. 11.0.11
It occasionally does succeed, but most of the time I get this error. I suspect it has something to do with the designer not properly loading projects over slower internet connections.
