v8.1.4, I’m trying to read, and then ultimately write, the priority of a configured alarm.
path = 'MyTagPath'
alarm = system.tag.getConfiguration(path)
print alarm[0]['priority']
and get KeyError: ‘priority’. I tested [‘name’] and that works.
How can I get the value for priority?
Looks like you can get access to it to read via system.tag.readBlocking…
system.tag.readBlocking(['[default]testAlarm/Alarms/Alarm.Priority'])
However it doesn’t seem like writing to it is supported.
Thank you. I was way off.
I noticed this post, Alarm Priority Type Error
Can we not write to the priority anymore?
It was easier to create my own associated data that I can easily read/write.
This is what I ended up doing to write to alarm properties as well, for what its worth. I drafted a couple posts to suggest doing this, but was hoping someone might come along with a more correct/streamlined solution. Glad you got it working.
