Hello, I've noticed that the same script returns "None" for some tags, but works just fine for the vast majority of others. Both are OPC tags belong to the same Data Type. The tags are basically identical as far as I can tell. Please see the script and console outputs below. Thanks for your time and help in advance!
configs = system.tag.getConfiguration(path)
# Iterate through the configs
for config in configs:
# If the tag has configured alarms, get them
if config.get('alarms'):
alarms = config.get('alarms')
# Iterate through the objects in the list alarms
for alarm in alarms:
print(alarm)
# Pull the alarm name
alarmName = alarm.get('name')
# Pull the full alarm path to dervie the label, priority, and enabled
alarmPath = '{}/Alarms/{}'.format(path, alarmName)
# Pull the alarm Label, Priority, Enabled
alarmData = system.tag.readBlocking(['{}.Label'.format(alarmPath), '{}.Priority'.format(alarmPath), '{}.Enabled'.format(alarmPath)])
alarmLabel = alarmData[0].value
alarmPriority = alarmData[1].value
alarmEnabled = alarmData[2].value
# Append the alarm data to the alarmList
# alarmList.append([tagPath, alarmName, alarmLabel, alarmPriority, alarmEnabled])
print([path, alarmName, alarmLabel, alarmPriority, alarmEnabled])
path1 = '[ProductGW]gPOR-(v3-2)/Bnx_FSA/DRS/AHU1/SPLY_FAN_STRSTP'
path2 = '[ProductGW]gPOR-(v3-2)/Bnx_FSA/DRS/AHU1/SPLY_FAN_DPSW804_STS'
output1 >>> {u'setpointA': 1.0, u'label': {u'bindType': u'Expression', u'value': u"replace(replace(substring({PathToParentFolder}, indexof({PathToParentFolder}, ')/')+2), '/' , ' '), '_', ' ') + ' '+ {name}"}, u'priority': Diagnostic, u'enabled': {u'bindType': u'Tag', u'value': u'[.]_enableAlarms'}, u'name': u'AHU Start/Stop'}
['[ProductGW]gPOR-(v3-2)/Bnx_FSA/DRS/AHU1/SPLY_FAN_STRSTP', u'AHU Start/Stop', None, None, None]
output2 >>> {u'setpointA': 1.0, u'label': {u'bindType': u'Expression', u'value': u"replace(replace(substring({PathToParentFolder}, indexof({PathToParentFolder}, ')/')+2), '/' , ' '), '_', ' ') + ' '+ {name}"}, u'priority': Diagnostic, u'enabled': {u'bindType': u'Tag', u'value': u'[.]_enableAlarms'}, u'name': u'AHU Supply Fan Run Status'}
['[ProductGW]gPOR-(v3-2)/Bnx_FSA/DRS/AHU1/SPLY_FAN_DPSW804_STS', u'AHU Supply Fan Run Status', u'Bnx FSA DRS AHU1 AHU Supply Fan Run Status', Diagnostic, True]
