Hi All,
I was wondering if there was a way to read grouped bits from a register. One of the devices I'm reading/writing from has registers that require you to read and write to grouped bits for different functions.
For example:
[Device_1]HRUS108 gives you an operating status at Bit 2 and Bit 3. 0=off, 1=,on, 3= fault, 4 = Error.
On the same device, Bit 14 and Bit 15 would be something like 0=Error, 1=Disconnected, 2 = Connected, 3= Alarm.
So there's a bunch of data shoved into one register. Different Registers require me to write to grouped bits as well, some of them spanning 3 total bits instead of 2 like the above example.
Here's another example of a sample register:
Bit 8 and 9 you could write to, however I'm unsure how to write to the grouped bits0-2 and bits10-15
Is this possible to do?
