Hi all,
Is it possible to read http://localhost:8088/main/data/vision/status/sessions with httpGet?
response = system.net.httpGet("http://localhost:8088/main/data/vision/status/sessions", username = un ,password = pw)
I’ve made a few attempts but always receive “IOError: Server returned HTTP response code: 403 for URL: http://localhost:8088/main/data/vision/status/sessions/” which seems to be authentication.
You would need to have a valid session ID cookie. Obtaining one is not trivial - for now, at least, you’ll need to make a separate request to the authentication endpoint, then use the JSESSIONID cookie used during that request to issue your actual request to the API endpoint.
Thank’s for your answer.
I managed to get the cookie, but I’m not sure how to pass that cookie when calling httpGet?
You can manually specify your JSESSIONID by passing a Cookie: JSESSIONID=<yourID> header in your POST.
