I apologize for the total noob question here but searching for an example for the past 2 hours pushed me to post…
I have several custom properties I created a for rectangle on a template. I just want to compare a value of one of the string custom properties so I can set an integer based custom property based on the strings value.
I believe my issue is that I am not reading the string value properly but my lacking syntax knowledge is crippling me…
if ({Mach_1040.Container.Port1.Monitor} = "YES",
{Mach_1040.Container.Port1.Port_Status} = 0,
{Mach_1040.Container.Port1.Port_Status} = 3)
Expression editor accepts this but I don’t get the desired changes in the Port_Status property. I believe I am not truly reading the string custom property Port1.Monitor value so it never evaluates the condition. Equally I doubt I am setting the integer custom property value of Port_Status properly…
Any pointers would be greatly appreciated…
