Reading Excel data into Ignition
I am looking at importing data from an old Excel-based Tracking system into Ignition.
the solution has to read Excel files in native format, preferably while the the spreadsheet is open on another computer if possible, because I need to leave the old system in place and running as I migrate to my new system over time.
I have seen several topics similar to this on this forum (reading Excel Data), but the resolutions are not good for me.(exporting to a CSV file, adding a new module, or building one of my own using the SDK)
I think I should be able to use the python module “pylightxl” but I don’t seem to be able to get that to work in side of Ignition Scripting.
any help is greatly appreciated.
Using Apache POI, which is now bundled with Ignition.
Hi, looks like ‘‘util.printDataSet.’’ is probably a user custom script called into the code? Looking to do the same thing, I want to import data from a excel ‘’.xls’’ or ‘‘xlsx’’.
Thanks for your help!!
That thread also links to the printDataset function, but has nothing to do with making the dataset itself. :wink:
Hi!
Thanks found everything! Wasn’t able to see the whole thread. :sweat_smile:
Hey Jordan, I’m stuck on this error. Are you able tell what i’m doing wrong?
The cell you are trying to get data on is returning None (null in Python-ese)
Figured it out thanls!
@Maxim_Drentom
Are you trying to import information from Google sheets into a database, or are you trying to write data to Google sheets from ignition using a database as an intermediary?
Hi c.turmel
I am facing the similar issue that you posted AttritubuteError:'NoneType' object has no attribute 'getCellType'.
Can you please suggest how did you figured it out.
You will need to handle a null in the code. The error will tell you what line the issue is on. One suggestion is only allow the code to execute if the value is not null.
@Divya_Chorge How to fix this issue. I'm facing the same issue.
