So I am working with support on this issue but wanted to see if the forum Gurus had any input on this as well.
We are working on an intergration with a client connecting to their BMS/EPMS data via an OPCUA connection (Ignition as the client) to their Niagara Supervisor OPCUA Server.
I have noticed the data quality since day one of successfully connecting to the Niagara Supervisor, has not been stable.
It will fluctuate from being Good to going to Bad("Bad_OutOfService: The source of the data is not operational.") at times.
I can see the timestamps and data updating on the Good points in designer. But to add to the pecularity of the situation when i use the OPC Quick client in the gateway even on the points that are reading good in designer I will get the Bad("Bad_OutOfService: The source of the data is not operational.") returned back with a value of null.
Here are my connection settings
Here is a snap of designer with good and bad quality data
Here is an example of the OPC Quick client returning a message when trying to read data that is showing good in designer
Also if it helps the data when i originally import into designer is configured as arrays such as a double array or a boolean array and i have to change it to double or boolean.
If anyone has run into similar issues or can provide any guidance that would be appreciated.
Steve
