I’m interested in reading out the result of an alarm property bound to an expression.
I know I can use system.tag.getConfiguration() to get a tags configuration including its alarm settings.
The problem is that if in my case the ‘enabled’ property of the alarm is an expression then all I get from system.tag.getConfiguration() is the expression itself.
What I need is the result/evaluation of the expression.
Same goes for the alarm priority property.
