How to Read values from Text file and assign them back to plc tags??? ![]()
Can you give an example of a couple lines of the the csv file long with the tagnames you want to write to?
here is the text file i hav attached. from this file i wanna read each value separately and want to assign them to plc tags
idle.txt (92 Bytes)
Ok, give me about a half-hour…
Does this file get appended to, so there is a new line every entry?
no the file wont get appended… only the values ll b updated in one line of text file and i want to read these values in ignition and want to assign them to plc tags
Okay, then. This will read a one-liner csv file and return the value as a list.
[code]
def readCsvAsList(path):
from java.io import BufferedReader,FileReader,File
br = BufferedReader(FileReader(path))
data = line.split(’,’)
return data[/code]
Then you con use the system.tag.witeToTags function to do the rest:
taglist=readCsvAsList("C:\idle.txt")
system.tag.writeToTags([Tag1,Tag2,Tag3,...],taglist)
Edit: Whoops! Wrong script!
[quote=“JordanCClark”]Okay, then. This will read a one-liner csv file and return the value as a list.
[code]
return data[/code]
Edit: Whoops! Wrong script![/quote]
Ill bet this doesn’t work. Where is line set. Might want to close br or you will leak memory.
[quote=“Kyle Chase”]
Ill bet this doesn’t work. Where is line set. Might want to close br or you will leak memory.[/quote]
Yep, you’re right. Should be more like this:
[code]def readCsvAsList(path):
line = br.readLine()
br.close()
return data[/code]
Thanks for the catch!
This wont work with his current file. readLine requires either a carriage return or a line feed, which his file does not have.
I stand corrected…
No worries here. Actually, I love these discussions. If it helps us to to stretch ourselves, then it’s all worth while!
The only other thing I would worry about is properly closing the file. Right now, you have no safety if an error occurs after opening the file.
In Java, I would do the following
try{
BufferedReader reader = new BufferedReader(new FileReader(path));
//parse data
}catch (IOException e){
LOGGER.info("Something went wrong",e);
} finally {
reader.close();
reader = null;
This should work, but doesnt. Maybe Jython 2.1 has no finally clause?
[code]
from java.io import BufferedReader,FileReader,File,IOException
try:
data = line.split(',')
except IOException:
log something
finally:
br.close()
return data[/code]
instead of using system.tag.writeToTag function for each tag path separately i want to use system.tag.writeToTags function coz i wanna read 300 tags from a text file.
