When i try to re-capture a component to a custom palette i receive the following error. v7.5.2
if save the project in between recaptures i will not receive the error.
[quote]java.lang.IllegalArgumentException: Cannot release lock 8997 when I am not the owner.
at com.inductiveautomation.ignition.designer.DesignerContextImpl.releaseLock(DesignerContextImpl.java:430)
at com.inductiveautomation.factorypmi.designer.palette.model.CustomPaletteItemGroup.update(CustomPaletteItemGroup.java:57)
at com.inductiveautomation.factorypmi.designer.palette.model.CustomPaletteItemGroup.itemUpdated(CustomPaletteItemGroup.java:64)
at com.inductiveautomation.factorypmi.designer.palette.model.DefaultPaletteItemGroup$1.propertyChange(DefaultPaletteItemGroup.java:36)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at com.inductiveautomation.vision.api.designer.palette.AbstractPaletteItem.firePropertyChange(AbstractPaletteItem.java:91)
at com.inductiveautomation.factorypmi.designer.palette.model.SerializedPaletteItem.setData(SerializedPaletteItem.java:87)
at com.inductiveautomation.factorypmi.designer.palette.views.AbstractCustomGroupView.copyPerformed(AbstractCustomGroupView.java:150)
at com.inductiveautomation.factorypmi.designer.workspace.CopyPasteHandler.doCopyOpToString(CopyPasteHandler.java:790)
at com.inductiveautomation.factorypmi.designer.workspace.CopyPasteHandler.doCopy(CopyPasteHandler.java:576)
at com.inductiveautomation.factorypmi.designer.palette.views.AbstractCustomGroupView.doRecap(AbstractCustomGroupView.java:105)
at com.inductiveautomation.factorypmi.designer.palette.views.AbstractCustomGroupView$PaletteItemPopup.doRecap(AbstractCustomGroupView.java:219)
at com.inductiveautomation.factorypmi.designer.palette.views.AbstractCustomGroupView$PaletteItemPopup$1.actionPerformed(AbstractCustomGroupView.java:188)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Ignition v7.5.2 (b1146)
Java: Sun Microsystems Inc. 1.6.0_33
[/quote]
