Recommend Server Specification
Hello, Is there a recommend server specification document detailing RAM , Memory , OS etc... Im looking to get a VM built and i dont want to order something that is underpowered.
Can check this guide
Thank you.
Make sure to ensure that the vm's resources are 100% dedicated, as mentioned in the doc. A lot of the time, IT will pretend to know what this means and they will "configure it", but really, they've just ticked a seemingly random checkbox somewhere that does nothing of the sort :confused:
Ok i will let IT know. Thanks for the info.
Also note that if the VM is going to be located off-site, the latency will crush the performance of polling PLC drivers. (OPC UA and MQTT are fine, though.)
Thankyou
