Recommendation for logging in without user name (securely)
Hello again. Revisiting this topic, been doing a lot of spring cleaning in this system.
Running 7.8.5
Using RFD system to log people in. But I just want them to scan the badge and that’s it.
Cleared out a lot of useless scripts and solved the many windows open plaguing the system.
Also instead of the excel spreadsheet the old person here did. I would like to use a DB user source so we can use the vision user management component to handle accounts. I assume this will result in better lookups as well.
I’m just not sure how to grab the username from the RFID#(password) if I use the DB user source. And I hate to leave a non secure table out there to cross ref the # to a username.
What would be a good cross ref secure solution?
Thank you in advance.
The lookup has to occur somewhere, unless the RFID token has challenge-response functionality. (Or one-time password generation, etc.) It it just supplies an ID number, you can’t really call it secure. Static tokens are easily spoofed.
@pturmel has spoken! Congratulations on your award!
