Recommended approach for automatically creating UDT instances when registering equipment in Perspective?
Hi everyone,
I’m working on a DCIM project in Ignition 8.3.1 Perspective.
Users can register Busways through a management screen. Currently, the Save button calls a project script that inserts or updates the equipment information in a database using Named Queries.
I would also like to automatically create a UDT instance when a Busway is registered, and update its parameters when the equipment settings change. Users would select an existing Ignition device connection from a dropdown, and that device name would be passed to the UDT as a parameter.
I’m considering calling system.tag.configure() in the same project script after the database save succeeds, using the database primary key as the instance name.
Is this a reasonable approach, or is there a better pattern for managing database records and dynamically created UDT instances?
In particular, how would you handle a case where the database save succeeds but tag creation fails? I’d appreciate any advice on keeping the database configuration and tag instances synchronized.
Thanks!
Does the information have to be in the database? If you can make the tags be the "source of truth", perhaps with some custom tag properties, you may avoid the need for the database.
For general examples of complex use of system.tag.configure(), consider studying the code in my Spreadsheet Import Tool on the Exchange.
