Just wondering if it is possible to reduce the length that the x-axis goes to the left hand side. I feel like for a time series chart, there will never be a negative time so that is valuable real-estate I would like to use.
Thanks!
Thanks!
Thanks this worked. Is there also a way to send this component to the back of the z-index so the axis does not overlap other components? I tried using "send to back" and it doesn't seem to work in the way I expect it to.
It should work. Make sure that you haven't got the chart in the same flex container as the chart and LED display. Note the structure in my Project Browser.
Tip: The LED display is not cool. You're mixing the 1970s with a modern HMI. They're hard to read and a label using TrueType or vector fonts would be so much clearer and give much better contrast.
If you can't get it to work then show your project structure.
