We’ve planned to use Ignition 7.7 for a new project with the following architecture :
2 Gateway in Redundancy mode with a warm backup.
MASTER GW @IP1, BACKUP GW IP2
We use KepserverEx to communicate with PLC.
sorry, uploading an architecture diagram doesn’t work in this topic forum ?)
We would like configure failover OPC Server Connection.
Failover Connection Settings must be différent between MASTER and BACKUP
(MASTER GW faileover opc server is @IP2, BACKUP GW faileover opc server is @IP1)
but these settings on the backup can’t be changed ???
How to achive this functionnality ???
I tried settings MASTER GW faileover opc server is @IP2,
the failover is ok, “switching to failoverConnect” in the log.
It will be usefull to have a more visible information in the gateway opc serveur connection diagram ???
When the primary opc server come back, can we have an option, like for the redundancy ?
Recovery Mode : Automatic / Manual, to switch back to the primaryopc server
