Redundant Gateway and dual NIC
Look under the Network Settings section of the following link. You can set Autodetect Network Interface and Autodetect HTTP Address to false and manually specifiy your settings - the .19.x addresses in your case.
inductiveautomation.com/support/ … ttings.htm
I know why you might use a different network for database or server communication, but I’m not following why you would use a dedicated interface with a crossover cable between 2 ignition servers. What would this accomplish?
