We have upgraded our system to Ignition 7.8.2, 2 month ago.
We encounter some trouble with opc-ua settings for client connection,
Our gateway is redundant.
We have to set on each gateway a local opc-ua connection to an opc-au siemens server.
When we configure the connection on master side,
with opc.tcp://localhost:4845, and press Discover,
We obtain :
opc.tcp://GTC-N-EST:4845
SecurityPolicy: Basic128Rsa15, MessageSecurity: SignAndEncrypt
SecurityPolicy: None, MessageSecurity: None
It’s ok for the MASTER, we use SecurityPolicy: None, but the connection on the BACKUP node is not the same ! … but these settings are sync between MASTER and BACKUP gateway !
(must be : opc.tcp://GTC-S-EST:4845 on the BACKUP side)
Any Idea? host override has no effect…
