Hello all,
This is a simple question but I couldn't find anything about it. If I have a redundant system and want to create a backup gwbk file, do I need to create one from the Master gateway and one from the Backup gateway, or is simply doing a backup from the Master gateway specifying "Download with Peer Data" sufficient (assuming that I select "Restore local-only Configuration files" when I restore)? It looks like after the Master is restored, the Backup resyncs and restarts automatically so a separate restore for the Backup gateway is not required and therefore making a backup of the Backup gateway isn't needed. Is that correct?
Thanks!
