We have a running redundant system onboard a vessel with very limited bandwidth (vsat), connected to 3 MySQL servers. Local, backup and remote. The remote SQL server is hosted in the AWS cloud. Both servers are always connected to all SQL servers.
As the connection goes down and varies a lot I made a gateway script running every 10 minutes checking the connection, disables is if not equal valid, and enables if status is disabled.
What we very often see is that the primary ignition server does not succeed in connecting, while the backup does. Still, on the MySQL client connections I can see two valid connections.
Is there a way to “disable” SQL connections on the secondary as long as primary is present?
Is there any recommendations regarding SQL connection parameters on such narrow band connections? I tried to play with time out etc, but is should be plenty. I can connect to the gateway interface and designer, but its slow.
The log tells me nothing about why it cant connect.
Client connections to databases are very sensitive to both dropped packets and latency, which are both terrible for satellite connections. You probably should consider a multi-master MariaDB setup, with Ignition only connecting to the local pair, and those propagating the changes as comms permit to the third server. (The local MariaDB servers should not be on the same computers as the Ignition gateways.)
Maybe the primary is failing as it s trying to send data from the S&F buffer. I do still find it a bit odd that it just says “Connecting” while the backup goes straight to “Valid”. On Friday when I implemented the gateway script I could toggle “Enabled” and it was working for almost two days.
Propagating is also possible between MySQL servers, but I would think it still need a proper connection?
Can you please elaborate why we should not run SQL servers on the same computers as the gateways?
What version of MySQL are you connecting to? Have you updated to the latest JDBC driver for MySQL?
Any errors in the MySQL logs that correspond to the event?
