I have a problem on my redundant server as it is always stopping and starting and after some time passes it is fully stopped. I cant seem to find what causes the problem.
MasterTCPChannel	18Sep2019 17:57:31	(id=60) Shutting down channel.
MasterTCPChannel	18Sep2019 17:57:31	Error occurred while communicating with backup client. Client has likely become unavailable.
MasterTCPChannel	18Sep2019 17:57:29	(id=61) Shutting down channel.
MasterStateManager	18Sep2019 17:57:24	System UID has been updated to '617d83d7-4de6-4314-9383-d4861efb1ae7'
MasterStateManager	18Sep2019 17:57:18	Backup node has requested a 'data-only' restore.
MasterTCPChannel	18Sep2019 17:57:18	System restore initiated by backup node. System will provide a data-only restore file.
MasterStateManager	18Sep2019 17:57:18	Connection registered from '/192.101.180.4:52810'
MasterTCPChannel	18Sep2019 17:57:18	Backup node is out of date - revision is not available on master node, so data-only restore will be performed.
DiskSyncManager		18Sep2019 17:57:15	Size of synchronization tasks on disk has exceeded the allowed maximum. Further tasks will not be stored, and the backup will need to perform a full restore.
MasterTCPChannel	18Sep2019 17:54:59	Channel did not see any activity within the specified failure timeout.
MasterTCPChannel	18Sep2019 17:54:57	Peer node information has been updated: RedundancyNode(address=192.101.180.4, httpAddresses=[http://192.101.180.4:8088/main], sessionCount=0, activityLevel=Warm, projectState=Unknown)
MasterTCPChannel	18Sep2019 17:54:56	Reporting master start time of Wed Sep 18 14:32:54 PST 2019
MasterStateManager	18Sep2019 17:54:55	Connection registered from '/192.101.180.4:52606'
MasterTCPChannel	18Sep2019 17:53:01	(id=58) Shutting down channel.
MasterTCPChannel	18Sep2019 17:53:01	Error occurred while communicating with backup client. Client has likely become unavailable.
MasterTCPChannel	18Sep2019 17:52:59	(id=59) Shutting down channel.
MasterStateManager	18Sep2019 17:52:54	System UID has been updated to 'bf859600-2173-4c96-a0b8-fb41565b4005'
MasterStateManager	18Sep2019 17:52:48	Backup node has requested a 'data-only' restore.
MasterTCPChannel	18Sep2019 17:52:48	System restore initiated by backup node. System will provide a data-only restore file.
MasterStateManager	18Sep2019 17:52:48	Connection registered from '/192.101.180.4:52426'
MasterTCPChannel	18Sep2019 17:52:48	Backup node is out of date - revision is not available on master node, so data-only restore will be performed.
DiskSyncManager		18Sep2019 17:52:45	Size of synchronization tasks on disk has exceeded the allowed maximum. Further tasks will not be stored, and the backup will need to perform a full restore.
Any help would be greatly appreciated. Thank you
