Wondering if there is any way to reference a cell within a dataset using the expression language and a column name. Referencing the column number is extremely fragile and error prone because if the columns ever change their order you’ll be referencing the wrong data. It also takes a lot of effort and time to count out the column numbers.
Dang! I could’ve sworn I tried that! I bet I didn’t put it in as a string. Thanks!
