I have a UDT definition that has a few UDT instances nested within it, for example Pump below.
The Main UDT definition has these parameters:
The Pump UDT instance has these parameters:
I am trying to reference the values of the parameters in the Main UDT (E.g. Description) within the Pump UDT (E.g. in Alarm_ParentDevice), however it’s returning the value of the Pump UDT’s Description instead of the Main UDT’s Description.
E.g.
Pump UDT’s Alarm_ParentDevice = “Pump” instead of “Mobile Pump Station 1 Pump”
Where the value is blank in the pump UDT, it does reference the Main UDT’s value (e.g. Alarm_Area and Alarm_ParentDevice), however if the value is not blank, then it seems to use its own value making it impossible to to cascade parameters
Is there any way to force the nested UDT to use the referenced values of the parent?
In this situation I usually use a second parameter in the nested instance (for example: Parent_Description) and use {Description} as the value. That’ll reference the parent’s parameter value.
I have a similar situation
-However both “Pump”-udt and “Sensor”-udt are inheriting from “Base”-udt
-Base-udt provides typical parameters to both, like “Name” and “Description” and “DeviceName”
UDT hierarchy:
Base<-Pump
Base<-Sensor
Pump/Sensor of type Sensor
Sometimes I use Sensor standalone and parameter DeviceName is used in OPC item path fex
The problem occurs when I try to add Sensor as a udt-type into my pump UDT (to save some engineering)
-Now both pump and sensor have parameter DeviceName. And the parameter name may not be modified since they both initially get it from Base :-/
Have I painted myself into a corner, or does anyone have a best-practice or idea how to get out of this corner
-Would it be nice to be able to explicitly address parameters of the “parent udt”?
If you’re embedding sensor into pump, then can’t you just override the sensor params in that pump udt? Or have I missed something
it is possible to call the parent parameter writing in the child one {Rootparameter_name}
Could you please expand on the syntax for this, i cant get it to work?
It's a simple matter of putting the parameter names in brackets:
Example:
{parameter1}{parameter2}{parameter3}{InstanceName}.SubTagName
