Refresh Alarm Priority after Tag Import
Hi all,
I am running into an issue when importing changes to tags. If a tags alarm priority is changed, but the alarm is currently active, the alarm will remain the old priority until the alarm is cleared. I am looking for a way to have the alarm remain active, but update to the new priority.
Is it possible to refresh all the alarms?
I can programmatically disable, then re-enable all of the active alarms. But this leaves an override on UDT tags enabled property.
Any suggestions to this problem are appreciated.
I don’t think you can do that with keeping the alarm in the active state.
I usually just right click, restart tag to get the updated alarm information.
