Hi guys,
I have a question about the alarm status table. I have a UDT with a alarm which occurs when a bit state is true. it generate a alarm which is fine.
I used the acknowledge button when i select the alarm, en the button send a acknowledge status to the PLC, where a other UDT acknowledge the real alarm. But i want to know in the table if the alarm is acknowledge, because the Ignition State column is not linked with the PLC, I don’t get this work, maybe someone know a solution.
So what i did, is writing a UDT tag which writes the value to true if the PLC is acknowledged (I used the ack pipeline column).
When the status occur i see the status which is false when i don’t used the acknowledge button, but when i press Acknowledge, the alarm in the PLC changed also the UDT tag to true, but the table row did not, so i still see false.
So is there a way to refresh a alarm row so it changed from false to true, refresh table or refresh alarm idk how to fix this??
