my question is: when pressing the 'change' button in the opened pupop window, what command should i use in the attached script to update the view elements behind it?
Thank you
Use a message handler.
Thank you !
You're welcome. Don't forget to click the "Solution" button to mark it solved. Thanks.
Done ![]()
If you can check my other issue ![]()
