Just a question about relative tag paths - I know that the [.] gets you to tags in the same folder, but just curious if there is a way to go up another folder?
I have several UDTs that share a common tag for some expression tags. Is there a way to reference that tag that is in the same folder as the UDTs with a relative path other than using a parameter to enter in the tag path? A […] perhaps? The manual didn’t say anything about it, but thought I would ask to be sure.
