Quick question that’s been plaguing me. Is there a good way to relatively scale templates that use anchored layouts?
I use a number of templates for things like pre-formatted numeric labels and text. These templates generally all use anchored scaling, allowing me to resize depending on the content shown. E.g. the following use the same templates, but are horizontally stretched to fit more characters:
Ideally I would set the template instances to use relative scaling, and have the object and text scale up/down with respect to the instance’s size. Here’s what I have in my designer:
Compare that to what’s shown in my Vision runtime (Vision application/monitor are larger than the window in the designer). Note that the template itself scaled (larger borders on templates), but the text is the same size as in the designer.
To summarize, is there a way to get the perks of both anchored layout within my templates AND relative layout in my window?
