is there any remote development option in ignition ?
whats the procedure?
If you have web access to the gateway, you can run a designer. As long as your network infrastructure allows that, you don’t need anything else to develop remotely with Ignition. Obviously, if not using SSL on your gateway, you’d better be using a VPN of some form.
