I'm endeavoring to establish a connection between two distinct gateways utilizing the Gateway Network feature, aimed at facilitating remote historisation from the edge to an Ignition server. I've attempted configuration adjustments, such as setting the ports to 8088 and 8060 (default) and deselecting the "Use SSL to connect to the remote machine" option in the outgoing network settings on the edge. Furthermore, I've unchecked the "Require SSL" checkbox in both servers under General Settings. Despite disabling the firewall on both servers, I'm encountering an issue where a WebSocket connection cannot be established upon saving the configuration. I have attached error images for reference.
Thank you.
