Hello all,
I would like to install ignition on a remote debian server, in the terminal over ssh. Is this possible? and how do i bypass/automate the interactive setup screens during the installation?
Thanks for your help.
Hello all,
The *.run file works just fine – I do the equivalent with headless VMs regularly. When there isn’t an X display to connect to, the .run file will present all questions in text mode.
You can also just use one of the zip distributions, which I prefer anyway, since they don’t shotgun files all over your system. Just unzip to /opt/ignition or whatever folder you like.
Thanks, I completely missed the zip packages.
