Hello,
I have two Ignition gateways: the first is Ignition Edge on my local machine, and the second is a standard Ignition instance on a remote server.
I have set up a network connection between the two, with Ignition Edge configured to connect to the remote Ignition gateway. Both gateways are accessible from each other; I can access their respective configuration web portals without issues.
Firewall rules are configured to allow all traffic, and I can successfully ping each gateway from the other.
However, I'm encountering an issue where Ignition Edge fails to connect to the remote Ignition gateway, resulting in the following error: Remote server forcibly closed the web socket: Session Closed. This connection worked during the initial setup but has since stopped functioning.
Below is a screenshot for reference:
On my Edge Gateway, I see the following log:
MetroWebSocket | 12Sep2024 15:33:11 | -> outgoing local='edge' remote='ignition' method=onClose: Remote server forcibly closed the web socket: Session Closed
And on my Ignition Gateway, I see these logs:
|12Sep2024 15:36:41|[100] edge connection status has been updated from Faulted to Shutdown: Remote is reconnecting|
|12Sep2024 15:36:31|[100] edge connection status has been updated from Initialized to Faulted: onClose has been called on web socket:Session Closed|
|12Sep2024 15:36:21|[100] edge connection status has been updated from Unknown to Initialized|
Has anyone encountered this issue before or knows how to resolve it?
