Remove ellipsis character in expression
Can anyone advise, how to remove a "…" in a expression?
try(replace(jsonGet({[.]../API Data}, "stateText"), "…", ""), null)
This does not work and the value stays the same.
Thanky you!
That is a single character ellipsis. Are you sure that is what you want to search/replace?
Yes sir.
It come from the REST API like this:
{"countErrors":0,"countWarnings":0,"countInfos":1,"currentLabelCount":301,"totalLabelCount":1200,"currentJobCount":1,"stateText":"Printing…","errors":[ ],"timestamp":"2024-03-21T12:46:54.904Z"}
  "countErrors": 0,
  "countWarnings": 0,
  "countInfos": 1,
  "currentLabelCount": 301,
  "totalLabelCount": 1200,
  "currentJobCount": 1,
  "stateText": "Printing…",
  "errors": [],
  "timestamp": "2024-03-21T12:46:54.904Z"
I've never tried this before with an expression but it seems to work.
if(
	jsonGet({value}, "stateText") = "Printing…",
	jsonSet({value}, "stateText", "Printing"),
	{value}
See Types of Tags | Ignition User Manual which may be relevant.
Tips:
  1. Use https://jsonlint.com to check JSON and to prettify it.
  2. See Wiki - how to post code on this forum.
