Hello,
Is it possible to remove the login of the client completely?
I can only find a automatic login function, but not a total removement.
Regards Benjamin
Hello,
Regards Benjamin
In perspective, its kinda setup that way by default. In vision, I don’t think that is an option. Typically if I don’t need any authentication, I’ll just create a generic user and set it up with auto login.
Thank you for your reply.
I also feared that is was not possible in Vision.
I wanted this feature, as I need the customer to login to 4 clients. So to ease the process a removal of login would be preferable.
Vision always requires some user to be logged in.
Automatic login of a “guest” user is the only way around it.
How do I set up Perspective clients to launch without the need to log in? Also is it possible to have that set to read-only?
