Hi please i need you’r help i can’t delete tags from MES
Not really enough information to go on, but I’m assuming you have Sepasoft modules installed. If that’s the case, you can’t add or delete tags because those are automatically generated based on your equipment configuration.
yes in sepasoft . i delete cells from equipement manager but all mes tags still existe in tags browser !!
Did you find out the solution? I'm having similar issues
