Removing duplicate rows from dataset
Beginning with a basic dataset, what would be the simplest way to remove duplicate rows of data?
Input ds:
ID   Value
01   val1
02   val2
03   val3
01   val1
02   val2
02   val2
Desired output ds:
ID   Value
01   val1
02   val2
03   val3
You can use a Python set to remove duplicates for you:
# get a list of your header names
headers = system.dataset.getColumnHeaders(oldDataset)
# convert to pyDataset, so the data is compatible with the set constructor
pyData = system.dataset.toPyDataSet(oldDataset)
# turn the lists into tuples so they are hashable
tuples = map(tuple, pyData)
# create a set from the list of tuples
pySet = set(tuples)
#convert set back into a list
newData = list(pySet)
#create an Ignition dataset from the headers and data without duplicates
newDataset = system.dataset.toDataSet(headers, newData)
