I create list of udt with differents attributs.
Now I want mofify the name of UDT but I met a problem Ignition give an error : does not writing of the tag and the project is Mode read/ write gateway.
Here is the script : system.tag.write("[]Tag.name",‘test’,1)
In fact, I generate several UDTs with a script which import file csv and add tag with differents attributs.
system.tag.addTag(parentPath=“ControlLoops”, name=“Test2”, tagType=“UDT_INST”,
attributes={“UDTParentType”:“ControlLoop”},
overrides={“conf_PV_max”:{“Expression”:"{[~]Boucle de Regulation/Boucle Classique/%s}" % row[“Mesure Process”] }…
No problem with this instruction but now I want modify just the name of UDT with a script, it’s not possible.
I can modify the differents attributes of UDT for example “conf_PV_max” with this instructions system.tag.write("[]Test2/conf_PV_max",‘Test’,1). but no the name.
Ignition generate an error tag does not writing with this instruction system.tag.write("[]Test2.name",‘Test’,1).
You understand now what is the problem, I try differents solutions none works
you cant write to every attribute using system.tag.write. you may want to try using the editTag function of the ialabs scripting module, that would be your best bet at doing this.
