Any chance to rename a tag folder via scripting?
A specific function is not documented, so I’m analyzing a creative solution inspired by
system.tag.editTag(tagPath="MyTag", attributes={"Name": "MyNewTag"})
I’m trying with
system.tag.editTag(tagPath="MyTag", attributes={"fullPath": "MyNewPath"})
or
attributes={"Path": "MyNewPath"})
or
attributes={"path": "MyNewPath"})
with no luck.
Creating a new tag and removing the old one is not a good way, since I loose the tag history.
Any advice?
Thank you
              Only thing I’ve found so far is your first solution
and following that up with an update query.  Example python script can be placed in Script Library and called after system.tag.editTag
def RenameTag(tag):
		#tag = {OldPath: 'Path/To/Tag',NewTagName: 'NewTag'}
		# renames 'Path/To/Tag' to 'Path/To/NewTag'
		err = None
		if not tag.get('OldPath'):
			err = 'OldPath not defined'
		elif not system.tag.exists(tag['OldPath']):
			err = 'OldPath Tag not found: ' + tag.get('OldPath')
		NewPath = '/'.join(tag['OldPath'].split('/')[:-1] + [tag['NewTagName']])
		if system.tag.exists(tag.get('NewPath')):
			err = 'Tag already exists: ' + tag.get('NewPath')
		if err:
			raise ValueError({'message':err})
		system.tag.editTag(tagPath=tag['OldPath'], attributes={'Name':tag['NewTagName']})
		system.db.runNamedQuery('api','RenameTagHistory',{'OldPath':tag['OldPath'], 'NewPath':NewPath})
and the NamedQuery RenameTagHistory (in the ‘api’ project):
Parameters:
QueryString | OldPath | String
QueryString | NewPath | String
Query:
update [dbo].[sqlth_te]
SET tagpath = REPLACE(tagpath,
					  LOWER('{OldPath}'),
					  LOWER('{NewPath}')
WHERE tagpath LIKE '{OldPath}%'
If you need to run this in the gateway scope, tag provider will need to be prepended to OldPath, and stripped back out before calling the runNamedQuery (sqlth_te table doesnt utilize tag provider in tagpath)
              I have noticed issues with this method though, using attributes: {Name} to rename a folder or tag has odd results.  Sometimes it renames the tag, sometimes it copies it, sometimes it renames it and everything underneath it disappears.  I wouldn’t recommend it.
