Repeated X Axis Values,
Hi Ignition Team,
I am having problem where the x axis values in my xy chart is repeating.
Please see attached images for the actual chart and the datasource.
[you can see from the image that Nov X axis values is repeating where as my data source only has Nov and Dec for the month. Nov and Dec are in current millins (https://currentmillis.com/)
1,732,982,400,000
Sun Dec 01 2024 00:00:00.000
1,730,390,400,000
Fri Nov 01 2024 00:00:00.000
You probably need to work with xAxes.0.appearance.grid.minDistance to get the effect you want. Have a read of Nick Minchin's reply on this topic. (It's about the y-axis grid so you'll need to convert to x-axis.)
